[EN] Focus Mk2 (EU, 2005) quick help
20 years ago
10
Ask for any help about Ford Focus Mk2 (2005) in English.
This topic is mainly for people who can't speak Russian - you can ask for any help and we will try to help you.
en_ffclub, fast help
ter
17 March 2004
168,1K
m_stavros
6 October 2016
VID_20161006_101743 by stavros mlls, on Flickr
m_stavros
12 October 2016
I had to move on with the rear brakes conversion so i took a deep breath and i started
IMG_20161011_165000 by stavros mlls, on Flickr
2016-10-11_09-04-25 by stavros mlls, on Flickr
2016-10-11_07-26-25 by stavros mlls, on Flickr
2016-10-12_05-11-37 by stavros mlls, on Flickr
m_stavros
18 October 2016
Finally i finished with the 302mm rear brakes and 15mm spacers!
IMG_20161018_140433 by stavros mlls, on Flickr
IMG_20161018_132731 by stavros mlls, on Flickr
IMG_20161018_132723 by stavros mlls, on Flickr
IMG_20161018_142836 by stavros mlls, on Flickr
IMG_20161018_150222 by stavros mlls, on Flickr
m_stavros
19 October 2016
And here is how it looks with 15mm wheel spacers on 7.5x17 ET42 rims
IMG_20161019_182813~01 by stavros mlls, on Flickr
m_stavros
24 October 2016
I think it's time to move on with the "bigger throttle body project"
IMG_20161022_185247 by stavros mlls, on Flickr
2016-10-24_08-52-04 by stavros mlls, on Flickr
m_stavros
30 October 2016
I am "in huge love" with that gear tower but is so expensive..
CAE Shifter Ford Focus MK 2 RS & ST
Product weight: 1,63 kg
Shipping time: 2 - 3 workdays
starting from : 929,00 €
including 19% VAT., plus shipping
Colour:
blank aluminium
black anodized » + 159,00 €
Variation & Colour of gear lever knob:
plastic black (POM)
white plastic ( POM Native)
aluminium titanium grey anodized
aluminium blue anodized
Aluminium Red anodized
Aluminium Orange anodized
Aluminium silver anodized
Exchanging of the Stock cables required
2016-10-30_02-53-14 by stavros mlls, on Flickr
2016-10-30_02-58-44 by stavros mlls, on Flickr
2016-10-30_02-56-04 by stavros mlls, on Flickr
2016-10-30_02-54-38 by stavros mlls, on Flickr
2016-10-30_02-57-26 by stavros mlls, on Flickr
2016-10-30_02-57-57 by stavros mlls, on Flickr
m_stavros
2 November 2016
So the new throttle body is much bigger than the stock one and the oem hose doesn't fit.. I use a large pipe expander tool to try to change the bore of the hose but it was very difficult as the expander opened from the free side only. I had to tie it to make it open equal both sides. Needed hot temperatures and patience..
80mm is the right size and i left it in hot in 83mm just to make sure that when it turns cold it will keep the right size.
These hoses have very strong "memory and they keep trying to turn back to the stock size..
2016-11-02_02-46-01 by stavros mlls, on Flickr
2016-11-02_02-44-08 by stavros mlls, on Flickr
IMG_20161102_144753 by stavros mlls, on Flickr
IMG_20161102_160609 by stavros mlls, on Flickr
IMG_20161102_164847 by stavros mlls, on Flickr
IMG_20161102_172614 by stavros mlls, on Flickr
IMG_20161102_175444 by stavros mlls, on Flickr
m_stavros
3 November 2016
Now it fits nice and tight!
IMG_20161103_162747 by stavros mlls, on Flickr
IMG_20161103_162801 by stavros mlls, on Flickr
m_stavros
4 November 2016
2016-11-04_02-41-58 by stavros mlls, on Flickr
IMG_20161104_160549 by stavros mlls, on Flickr
IMG_20161104_171959 by stavros mlls, on Flickr
IMG_20161104_171928 by stavros mlls, on Flickr
m_stavros
4 November 2016
IMG_20161104_184142 by stavros mlls, on Flickr
IMG_20161104_184201 by stavros mlls, on Flickr
m_stavros
8 November 2016
The 10mm H&R wheel spacers and the longer studs for the front wheels have arrived.
Here is the product code and a close up photo for anyone who's interested.
IMG_20161108_144828 by stavros mlls, on Flickr
IMG_20161108_144903 by stavros mlls, on Flickr
m_stavros
9 November 2016
IMG_20161109_170558 by stavros mlls, on Flickr
IMG_20161109_170609 by stavros mlls, on Flickr
m_stavros
10 November 2016
So now i got an unexpected major problem.
I cannot change the front wheel studs with the H&R longer ones because there is not enough space on the back side of the hub.
I must put out the wheel hubs - change the studs on a bench and then press the hubs back in...
It was something that I couldnt predict..
m_stavros
16 November 2016
I thought about it but I only need 10mm spacers.
m_stavros
25 November 2016
Mazda 3 mps BK 2007-2009 anti roll bars arrived a few hours ago. I am curious to see if they fit properly.
2016-11-25_03-20-19 by stavros mlls, on Flickr
m_stavros
21 December 2016
After a month of waiting the anti roll brackets arrived! Here is the mazda product code and a close up photo.
IMG_20161221_145139 by stavros mlls, on Flickr
IMG_20161221_145210 by stavros mlls, on Flickr
m_stavros
23 December 2016
IMG_20161222_115257 by stavros mlls, on Flickr
IMG_20161222_115323 by stavros mlls, on Flickr
m_stavros
23 December 2016
The rear bushings were advertised to be 25mm but it was 23mm.. So i got an open space on the top of bushing.. I hope that it make no difference.
The result on the street is amazing. The handling is really awesome!
IMG_20161223_150214 by stavros mlls, on Flickr
m_stavros
27 December 2016
I also install the front anti roll bar today. The feeling is amazing it is much better than i expected!
Another thing is that the Siberian bushings seems to be better than the well known Powerflex.
clepsy
28 December 2016
Hi,
I added to my crap 1.4 80 hp the increased throttle body of ff3
And also replaced to fuel injectors with the new Bosch ones from ff3 also, it has 4 holes instead 2
Runs much better, idle consumption dropped to 0.5l/hour from 0.7l/hour, will check the rest in the next days as I have a trip of 600km
I do believe that a tuned software may help a bit also, tried 7M51AKB_L7 originally tuned from 1.6l as now this give me best results, if anyone have different opinion let me know
m_stavros you did a lot of things to your focus nice
m_stavros
28 December 2016
clepsy Do you have the finis code of the ff3 injectors?
Thank you.
clepsy
28 December 2016mobile
Here you can find even pictures: Взаимозаменяемость запасных частей ФФ2 и ФФ3 (сообщение #16635968)
m_stavros
23 January 2017
Moving from 5w30 Amsoil to 5w40 Castrol Edge
2017-01-23_04-04-55 by stavros mlls, on Flickr
kewert
27 January 2017
Hello
I want to improve rear nozzle in Focus MK2 before lifting. I found this "Заднее стекло хетчбека/дворник/омыватель и тд." in FAQ: ffclub.ru/topic/11975/jump_400/#entry7090109 but i dont understand what I need to do it. What noozle I can use and what actions I need to do? Original washer is too weak. Can you help me?
kewert
27 January 2017
RU: какие омыватель я могу использовать на заднего стекла в фокус мк2 хечбек? завод ест слишком слаб для мне. Извините за мой слабы рускиий.
EN: What jet I can use in ford focus mk2 hatchback on rear window? Stock washer is soooo weak. I want to improve it. Sorry for my bad russian. If it is possible, please reply me in english.
Thanks in advance.
Ivan_F1
28 January 2017
kewert
I do not think that the washer is a problem. The main problem - rear wiper FF2, and the problem is solved by replacing it. What is discussed in this topic.
kewert
28 January 2017
Ok, thanks, I will replace wiper but washer in my car is weak too. I must use too much liquid to make rear glass wet. What washer from which car I can use to replace stock? Chevrolet Niva washer is not available in my country.
Ivan_F1
28 January 2017
kewert
May be problem in stock washer, it must be cleaned or changed on stock too. I don't have a problem with stock washer.
m_stavros
2 February 2017
A few hours ago i received this new thermostat with housing. It was in the 1/4 of the genuine ford price and i thought that might be a chinese crap BUT.. It's seems like a very good quality product and it is made in Sweden!
IMG_20170202_174810 by stavros mlls, on Flickr
IMG_20170202_174928 by stavros mlls, on Flickr
IMG_20170202_174906 by stavros mlls, on Flickr
m_stavros
3 February 2017
The RS oil cooler is bigger than the ST225 and helps the oil to run in lower temperatures.
The ford genuine part is from Volvo, the brand is Behr and costs about 350€ .. So i order one from Behr that costs less than half of the price. It is exactly the same.
IMG_20170203_145554 by stavros mlls, on Flickr
IMG_20170203_145541 by stavros mlls, on Flickr
