[EN] Focus Mk3 (2011) quick help
4 years
Ask for any help about Ford Focus Mk3 (2011) in English.
This topic is mainly for people who can't speak Russian - you can ask for any help and we will try to help you.
Also check our most popular topic for international visitors: Ford Sync 3 - multimedia and navigation (RU) - it's in Russian but you may use Google Translate to post, it's ok there 🙂
en_ffclub, fast help
ter
28 May 2005
286,2K
cavallo76
3 April 2017
Universe
Hi dear. Can I use BM5T-18C815-HL can whit sync 2?
Universe
3 April 2017
cavallo76
Yes sure.
semetka
5 April 2017
Hy.
I have two question.
1. I have BM5T-18C815-GE but I would like to change BM5T-18C815-HN.
Compatible with each other the two ACM?
2. BM5T-18C815-GE : Where I can download sw updates?
thatkey
10 April 2017
Where I can download two files , F1ET-14C026-AME.VBF and F1ET-14C026-PE.VBF .
www.fordtechservice.dealerconnection.com/vdirs/wds/PCMReprogram/DSFM_PCMReprogram.asp?swproduct=IDS
This link shows "Error: File (F1ET-14C026-AME.zip) Not Found. Please click Return to Download another file"
THANK YOU VERY MUCH.
thatkey
15 April 2017
I have found two files F1ET-14C026-AME.VBF and F1ET-14C026-PE.VBF but i cannot edit last post .
Now i have another problem i cannot find the file named F1ET-14C026-ANE.vbf .Can you give me a hand ?Thank you very much .
dazst250
16 April 2017
This is what I have on mine from my 2015 focus ST3 UK model. I don't know if this is any help to you
Module Name: IPC
F108 - ECU Network Signal Calibration Number : F1ET-14C318-AB
F111 - ECU Core Assembly Number : F1ET-14F094-JB
F113 - ECU Delivery Assembly Number : F1ET-10849-AKH
F120 - ECU Software #2 Part Number : F1ET-14C026-ACG
F121 - ECU Software #3 Part Number : F1ET-14C026-ASF
F162 - Software Download Specification Version : 0x04
F163 - Diagnostic Specification Version : 0x03
F188 - Vehicle Manufacturer ECU Software Number : F1ET-14C026-ABH
F18C - ECU Serial Number :
Betamax_man
16 April 2017
Don't know if anyone can help?
I cannot edit my 64 plate 2015MY Focus as built configuration. I have tried Focccus and get the unable to load secondary bootloader error when trying to load from the car. I have tried to locate the calibration file but also cannot find it. The file listed both in Focccus and Forscan is F1FT-14C094-AD. Interestingly, I have access to IDS and this fails to read the configuration of the car BCM. Any ideas?
arcomp
26 April 2017
Hello friends,
I was install oem adaptive cruise control after market on 2015 model year Ford focus Mk3,5 1,6 TDCI Titanium Europe version.My car is 6 speed Manual transmission.There is no any DTC in my car.I did the radar calibration with IDS.Working perfectly. But I have problem.
PROBLEM
1)Res/+ and LIM CAN/OFF key not function.Other keys function working.I use this key part number F1ET-9E740-CB for adaptive cruise.I did not make any changes to the steering whell harness.
I use direct config module asbuilt data.
764-01-01------> 040A 0000 027D
764-01-02------> 016F
BCM asbuilt is:
23--->03
96--->02
97--->02
224->02
PLEASE HELP ME FRIENDS
AuRoN89
2 May 2017
Hello friends, i have Ford Focus ST MK3.5 with factory ACS.
I want to add Lane Keeping and Traffic Sign Recognition... since i already have the ACS lidar, i suppose that i only need the additional camera for the other two functions. Do i need additional or modify some wiring harness?
Thanks
cavallo76
22 May 2017
Universe
Is The cooling system in the photo
Compatible with focus c-max?
Universe
22 May 2017
cavallo76
Yes, these parts are for 5" Navigation LCD Screen cooling.
rfr78
26 May 2017
Hi!
is it possible to install Focus MK3.5 (facelift) LCD radio screen (F1FT-18B955-xx) into Focus MK3?
Currently I have basic radio with two line monochrome LCD.
regards
rfr78
Universe
26 May 2017
cavallo76
C-Max (MY2010) has different part-numbers
Hose
AM5118D810AB - FORMSCHLAUCH
Brand FORD: AM5118D810AB - FORMSCHLAUCH
Partno.: 1715393
Other part I can`t find
try here http://www.fordcat.ru/shop/1/catalogue/155
cavallo76
29 May 2017
Universe
Hello.
I bought sync 2.
I am starting mounting and now i have problem whit steering wheel controller.
I have these controllers
Down controller don't work. Upper control work as this
(If i push "ok" start vocal control, left arrow start phone, ECT)
In asbuilt this controller are activated.
which is right configuration? I must to change part number?
Universe
29 May 2017
cavallo76
If you want to keep 2-controller managing You need to change them both to M button instead of OK and two-stars instead of lower controller.
I mean you need these:
Also you need to change steering wheel wiring loom to FINIS 1801775 or rebuild current one upon this post - Ford SYNC® и MyFord Touch® (сообщение #18265775)
cavallo76
29 May 2017
Universe
Thank you Universe.
I have another problem.
Apim Hardware
Acm hardware
BM5T-18C815-HL (dab)
If i turn on system, radio tell me Entertainment not available
Must i to change apim configuration?
If yes, How should I do it?
FLA
30 May 2017
Universe:
FLA
Hi
the chineese camera will work correctly BUT it needs to flash the LCD with one of the modified software. One of them iwas made by Quickie (presented in ADS) and the second by DarkLeo (presented in UCDS).
Hello
what is the difference between Quickie and Darkleo software? I have rear parking sensors and I think that after LCD flash there will not see the graphic sensors on LCD screen, is it true?
Universe
30 May 2017
cavallo76
It seems you need to switch OFF DSP module in APIM configuration
FLA Hi
Quickie`s Software work immediately, i.e. you don`t need to switch Rear camera in Asbuilt.
DarkLeo`s software was made so that you need to change Asbuilt and reset the FCDIM. Then camera works.
If you have rear-only Park assistant only then you can`t see it in both type of SW. Only BEEPING!
If you have semi-automated park pilot (SAPP) then you will be able to see FRONT parking sensors while driving in reverse.
cavallo76
30 May 2017
Universe
Do you know dsp bit?
Universe
1 June 2017
cavallo76
Try
7D0-01-01 *xxx xxxx xxxx
Sony Sound Processor: A=enabled, 2=disabled
dazst250
7 June 2017
Universe
Hi Universe
Do you know anywhere I can get the sync 3 screen and apim from, nothing on ebay at the moment and the UK just seems to be in short supply of second hand ones??
Cheers
Darren
gligamesh
16 June 2017
Hi,
My 2012 Focus is base version and coming with low radio. But previously I've changed my MFD to MFD5 with nav and also bezel and now all features of MFD is working like Titanium version except SYNC
I know it is not easy but my question is there anyone who installed SYNC?
Universe
16 June 2017
gligamesh
A lot of forum members did.
gligamesh
16 June 2017
Hi @Universe,
Sorry if I'm asking an already answered question. I'm new in the forum and I'd appreciate if you can send me link to related thread.
Thanks in advance.
Universe
16 June 2017
gligamesh
Start from Here
Universe
16 June 2017
gligamesh
additional info
gligamesh
16 June 2017
Universe
Thank you. I've started reading all the subjects.
But let me ask you a question first.
I've purchased all the necessary equipments. New head unit + sync module + wiring + mic. But when I've dissambled to install it, I've seen that there's no power supply coming from my original wiring to sync. So if I even install sync; it's not powered up. Could you please simply tell me how to power up sync using my original wiring?
Universe
16 June 2017
gligamesh
According to schematic you can power SYNC module to the ACM (audio control unit).
pd3jcw
22 June 2017
When upgrading a sync3 unit without navigation to a unit from a wrecked car with original navigation, do i have to change the VIN number that is programmed in it ? Or will it lose the navigation function when i do that ? (i have a UCDS for this)
D-K
23 June 2017
pd3jcw
I think it's not necessary. The VIN should be automatically assigned to the Sync3 unit when you connect to the car.
However, let's wait for experts like Universe to comment.
