[EN] Focus Mk3 (2011) quick help
4 years
Ask for any help about Ford Focus Mk3 (2011) in English.
This topic is mainly for people who can't speak Russian - you can ask for any help and we will try to help you.
Also check our most popular topic for international visitors: Ford Sync 3 - multimedia and navigation (RU) - it's in Russian but you may use Google Translate to post, it's ok there 🙂
en_ffclub, fast help
ter
28 May 2005
287,4K
duorw
25 May 2015
ittrium:
duorw
Seems that now it is not ELM327 related problem.
The problem is that your IPC doesn't accept the secondary bootloader to the address it is uploading.
Maybe your IPC is different and is not supported by FoCCCus yet.
I will check the right bootloader according to your log a bit later and will let you know.
Hi Irrtium,
May I know if there are any progress for this?
Thank you very much.
Universe
25 May 2015
tracer
Cruise control does not work with this steering wheel
Airbag jack is different
Devillous
5 June 2015
Hi
Could you post the link to the thread where someone has installed the SYNC in pre Facelift Focus?
Just found the foto...
thanks!
Universe
6 June 2015
Devillous
Which Sync version are you interested in?
Devillous
8 June 2015
sync 2.0 which is standard in the FF3 Facelift (big touchscreen)
Universe
8 June 2015
Devillous
I did.
Ask me what you are interesting
Devillous
10 June 2015
would be perfect if you could send a link with a tutorial
is it plug and play?
Universe
10 June 2015
Devillous
First, please click the nickname of the forum`s member before typing if you want him to recieve a notification of new message. Ok?
Well I don`t have a tutorial it because about 90% is in my head. In common word you need to change/install about 20 new parts and add about 20 new wires to an existing looms.
Moreover it nees to be reprogrammed with Ford IDS/VCM.
tracer
10 June 2015
Universe
I have one question.
I am looking for Ford Focus ST MK3 electri schematic.
I want to install:
Boost / Oil Temp / Oil Pressure gagues from ST to My MK 1.6 EB.
I am looking for ST Mk3 Scematics.
duorw
29 June 2015
ittrium:
duorw
Seems that your ELM327 is not stable or fast enough. Is it based on FTDI chip? If so, try to set timeout to 1 ms in device properties in device manager (default is 16 ms). And if it doesn't help, enable logs in FoCCCus and share here.
Hi Ittrium,
Much appreciate if you could let me know any progress for this.
Thanks in advance.
Regards
tracer
5 July 2015
Hello,
I am looking for scematic for:
I know it is 6-pin socket with 5 cables.
CAN - white-blue, white, black(zero) and 2 more cables. (violet-white and ??? )
Could somebody check where this pins come from or has just scematic for that ?
Thanks
tracer
5 July 2015
Anybody has an idea ?
Can somebody take out form his ST gauges and check by multimetr where goes pins to
C21B ?
firesanek
6 July 2015
tracer
6 pins, but use only 5
1 - VT/RD - + KL30. from pin№3 Instrument Cluster
2 - BN - illumination, should use from illumination switch of heated seat
3 - BK - GND
4 - WH-BU - CAN
5 - WH - CAN
6 - not use
tracer
6 July 2015
firesanek
1 - VT/RD -+ KL30 what does it mean ? Just a pin3 in instrument clusters ?
2 - BN - illumination - lights You mean - I do not have heated seats. any other idea?
firesanek
6 July 2015
tracer
1 - power supply from battery, can connect to 3 pin on the instrument cluster
2 - can connect to 3 pin of the FCIM (button panel of the audio system)
tracer
6 July 2015
firesanek
Power Supply is 5v or 12v ?
firesanek
6 July 2015
tracer
12 V from battery
tracer
6 July 2015
firesanek
Thanks.
So I was connecting it in 1.6 EB.
1. Oild TEMP - OK
2. Boost - NOT OK
3. Oil Pressure - so so - it works but seems that calibration is diffrent then in ST
Thanks for help
tracer
18 July 2015
Universe
Could You update me about that ?
What has to be changed to install LIFT ST Steerwing Wheel ?
Thanks in advance !
tracer
24 July 2015
Universe
Could You help me with that ? BCM is need from Lift ?
Universe
24 July 2015
tracer
if steering wheel without cruise-control then you need only to change airbag connector.
tracer
24 July 2015
Universe
My Genuine FF 3.0 has Cruise Control
The ST 3.5 Lift has Buttons to.
I want to buy new AirBag for ST MK3,5, but I want to get working Cruise Control.
Thanks for help.
Universe
24 July 2015
tracer
Cruise will not work.
It seems (but not approved yet) that it needs need new BCMi and/or steering wheel clock module.
I had ordered one.
tracer
24 July 2015
Universe
Thanks Universe
Please keep us informed.
Universe
24 July 2015
tracer
But i had already installed F1FT BCMi - from 11/2014 C-MAX
tracer
24 July 2015
Universe
Hmmm but if You install new BCM and it still does not work, it means that Steering wheel module needs to be updated.
VIN Number: WF0KXXGCBKEL60694
BCM: DV6T-14A073-HJ
It can be too old then.
tracer
3 August 2015
Universe
Hello Universe, I have seen that You have fitted MK 3,5 Instrument Clusters. I have fitted to but I have problem with PARK ASSIST.
No more sound when I put R gear to go back... only visualisation on the radio screen... but no more sound. Do You have sound when You get closer to other car or wall ?
Universe
4 August 2015
tracer
hello. there is no solution for this issue yet.
tracer
4 August 2015
Universe
Thanks a lot for Your answer.
If I put older Instrument Cluster from ST ( 2013 )
Does sound and park assist works fine ?
Is there a chance to set up odometer by ELM237 ?
tracer
4 August 2015
Universe
I can not edit anymore my post so I put SCAN log:
===PAM DTC U0121:87-28===
Kod: U0121 - Utrata cznoci z moduem sterujcym ABS
===PAM DTC U0415:86-28===
Kod: U0415 - Nieprawidowe dane odebrane z moduu sterujcego ABS
===PAM DTC U100B:00-28===
Kod: U100B - Pautomatyczny ukad parkowania rwnolegego
I guess it needs new PAM + 2 new rear sensors + bcm.
