Fma965
UK (GB)
Аудио, мультимедиа, навигация3 years
Fma965
19 October 2020
1U5T-14G421-BJG
https://ivsubinaries.azureedge.net/swparts/1U5T-...TAR.GZ
21.98 MB
3.2.20071
18C7F5270E4C2CA3BD7E8F247876C63E
Добавлено.
Added.
Fma965
15 September 2020
NaviExtras Nav packages - 2019Q4
http://cdns.distrib.naviextras.com/content/!app...9Q4.tgz
Not from ford blob but i see others in the post that are from naviextras also
Does any one have blob links? i've tried but no luck.
Fma965
14 September 2020
Missing 1U5T-14G421-BJG from the seperate url's
Fma965
14 September 2020
Серый:
XroMSPb
А почему [SYNCGen3.0_ALL] а не [SYNCGen3.4_ALL]
it's because its SYNC Generation 3.0 and ALL versions of Sync Gen 3.0
Fma965
13 September 2020
Airborne_Ape:
Sync 3.4 20184
возможно =
5U5T -148G381-EF
5U5T-14G391-DM
probably a typo, 5U5T-14G381-EF surely
Замена (увеличение объема) ПЗУ на Sync 3 Аудио, мультимедиа, навигация Focus 3
Fma965
10 September 2020
Think i answered my own question
Fma965
10 September 2020
RU: Работает ли дочерняя плата / плата хранения my16 + с устройством MY18.5 +?
У меня старый считыватель eMMC, поэтому я не могу прочитать новый макет, но у меня есть запасные старые микросхемы хранения
EN: Does a pre MY18.5 daughter board / storage board work in a MY18.5+ unit?
I have a older eMMC reader so can't read the new layout but have spare old storage chips that i wanted to swap out in my personal car
Fma965
23 August 2020
S
spardo:
your error bump into apps your sync witch navi ?
Try this for NAVI Version 3.3 i flash 10+ cars Focus Edge Fusion C-Max Escape 2013-2019 and all good
Or this Without
Yes it doesn't matter what packages i use or if i use nav or not it is still the same error at the apps stage, this is a 64gb EU NAV APIM. it's quite odd, i have never seen this issue before.
Fma965
21 August 2020
Any one had this issue? i can flash the chip directly no issues or errors but if i try to flash via reformat i get this. doesn't matter what usb i use, what version of sync i use always same issue.
У кого-нибудь была эта проблема? Я могу прошить чип напрямую, без проблем или ошибок, но если я попытаюсь прошить через форматирование, я получу это. Неважно, какой usb я использую, какую версию синхронизации я использую всегда одну и ту же проблему.
Fma965
19 August 2020
direct ford links anywhere?
Map License: 4U5T-14G424-FBH.tar.gz
Map: 4U5T-14G421-FBH.tar.gz
Ford Sync 3: кастомные прошивки и видеоплеер Аудио, мультимедиа, навигация Focus 3
Fma965
3 July 2020
Does Sync Use NCM drivers over ASIX now?
Использует ли Sync драйверы NCM поверх ASIX сейчас?
Fma965
20 June 2020
D
Dextervio:
louage
https://www.drive2.ru/l/554099435647271359/
unfortunately this does not work on FF
к сожалению это не работает на FF
Fma965
18 May 2020
K
KingArtur:
Доброго времени суток, уважаемые форумчане!
Sync 3 был прошит ещё месяца 2 назад на версию 3.4, все было замечательно, но вот дня три назад начало происходить непонятное - в CarPlay иногда невозможно отрегулировать громкость музыки во время проигрывания, происходит регулировка голосовых указаний.
Пробовал сбрасывать настройки, сбрасывать клемму аккумулятора, закрывать все приложения, перезагружать телефон, удалять устройства, менял кабеля... в общем перепробовал все известные мне способы, но так и не удалось побороть проблему.
Подскажите пожалуйста, если кто сталкивался с подобным - как лечить данный недуг?
yes as mentioned, waze is the issue https://www.autoevolution.com/news/google-owned-...30.html
Fma965
4 May 2020
is the eMMC encrypted? can it be read directly via soldering?
Fma965
26 March 2020
MickaelFR
EN: Hard reset as in Next + Power or Master Reset in settings? i've tried both with no luck. any other ideas?
RU: Хард ресет как в Next + Power или Master Reset в настройках? Я попробовал оба без удачи. какие-нибудь другие идеи?
Fma965
7 March 2020
To clarify i also get no signal in the testing settings or location details or satellite history
Fma965
7 March 2020
EN: Has any one else had issues with GPS not working at all after using the reformat tool, me and 2 others can no longer get any GPS signal despite changing app version, master resetting and changing forscan settings, does any one have any ideas? i tried googling but not luck
RU: У кого-то еще были проблемы с тем, что GPS вообще не работал после использования инструмента переформатирования, я и еще двое больше не можем получить сигнал GPS, несмотря на изменение версии приложения, сброс настроек мастера и изменение настроек forscan, у кого-нибудь есть какие-нибудь идеи? я пытался погуглить, но не удача
Fma965
27 January 2020
Dik_g:
try changing: de00
i have fixed DAB and various other things and no APIM DTC but i nav is showing as Navigation Fault, i will try re-installed the nav data in the future
Я исправил DAB и другие вещи, и нет APIM DTC, но навигация отображается как ошибка навигации, в будущем я попытаюсь переустановить данные навигации.
Fma965
26 January 2020
Dik_g:
try this config download
This is Russian language
i have got rid of the error but nav just shows "loading map" now and doesn't work, DAB no longer exists either, i know how to fix the radio but not how to fix the nav.
Fma965
26 January 2020mobile
Dik_g:
this will download the configuration from the FoMoCo server, according to your VIN car number.
provided that you did not look for sync (ampi) updates via wifi, in this case the config is transferred to the FoMoCo server and saved there
This has got rid of initial configuration not complete but now I have u2101 control module configuration incompatible
